Silverado 6L80E Transmission Thermostat Delete
no trans stat, and a 175 engine stat,  gives me  an operating range of 135-150.. i will be adding a trans cooler and the deep trans pan off the ss camaro next, because i will be towing a camper in a few months, i'm curious what those numbers will yield.
if you do hard driving and racing on the street or track,  the temp easily climb up to 185-190 with the delete, but if you drive like a normal person  you should operate at 145 all day long
Edited by flyingfool
9 hours ago, Ltz4 me? said:
Ok, so how much did you drop extra b/c of the 175deg water stat change in addition to the pill flip?
I wonder with the new synthetic fluid upgrade as the latest TSB if 180-200 is less of a problem in some way due to if let's say this fluid can withstand a higher temp than the standard transmission fluid?
What exactly are you looking for?   What are you afraid is going to happen?
I think the science has been answered already.
Repeatedly.
There are no straight polyol esters but there are some polyalphaolefin/polyol ester blends. Red Line D6 is one. A good one.
The 'continuous' operating temperature would be between the two so somewhere between 200 F and 225 F ish. That is the ONLY range anyone should even consider. Doesn't matter that it will take more over a short period.
Your factory fill is a Group III mineral oil. Mobil 1 ditto. Yes Group III will take a bit more than the Group II; the mineral oil shown will take but a few degrees, not multiples of 10's higher. Perhaps 180 F ish.
Note in the upper chart that varnish starts to form at 220 F. (Mineral oils) Seals start to harden at 240 F. Just how close to failure would you like to operate at? The seals don't care what fluid is in it. OilByType.jpg.2e2243eaff9da9ea556d8462995893c8.jpg
On 9/3/2020 at 10:00 AM, Ltz4 me? said:
How can I tell if I have this transmission?
Will it stop erratic shifting if I've already deleted afm with a mpg tune?
Thanks fellas
I certainly appreciate then need to know before jumping how deep the water might be. So lets start over.
Back to your original post. I offered this companies product before but here is the tech on it. And the exact product.
https://www.lubegard.com/wp-content/uploads/2019/07/GM-8-speed-shudder-flyer_all_sizes.pdf
As far as what the Mobil 1 Synthetic LV ATF HP transmission fluid is.....I have no idea. It's a newer fluid I haven't any experience with nor knowledge of bfeyond a post on BITOG......
I seems the friction modifier package was adjusted in an otherwise regular DEXRON HP ATF. Meaning the base oil is still what it always was.
https://www.bobistheoilguy.com/forums/threads/atf-solvesgm-transmission-shudder-issues.303084/
That the case cooling is to be treated as if it were worst case. Keep it under 180 F. The shudder is a separate issue. Change fluid to the new or Lubegard.
At this point I have nothing left to offer you. Thanks for the dance.
  • 2 months later...
On 7/30/2020 at 2:32 PM, rav3 said:
@Grumpy Bear     thanks for the link. I looked at it & wonder how does this device for $50 work any differently than just reversing the internals of the thermostat to by pass the unit? Looks like it has a spring loaded ball check valve. Just curious...
This video shows a simple way to "bypass" the transmission thermostat.
https://youtu.be/rYP6CMgfbwU
The kit has an internal 'safety' bypass should the cooler or cooler line plug. No such safety when using the 'flip' or 'plug' methods.
On 8/9/2020 at 8:27 AM, rav3 said:
Sorry about that. I was worried about the C-clip as well. Below is the video as mentioned below. However, I would reach out to him to see if he would send you the parts. Or just go down to auto store & get a couple springs as close to size in the unit.
Aaron Hines is his name. I'd go to one of his latest videos & send him a comment requesting help. Good luck
https://youtu.be/roqDBeR69ac
Does anyone know of a video of this "pill swap"  The only thing I have ever "tapped" was a woman.  :)
That's so sad. You've never tapped a keg?
Someone else can have a turn Googling these video's  and post them here
After a dozen or so, I'm done
Edited by Grumpy Bear
I'm a Rum drinker :)  I did google first all I could come up with was the tap method. Maybe  I should look harder?
Edited by IndyRob K.
  • Haha 1
  • 3 months later...
Bringing up the dead here but it seems the OEMs and their maintenance charts are a bunch of phooey if you look at the ATF performance temp charts.
GM front drives and now most of the rear drive applications have some sort of thermostat control on them.  It seems fluid suicide running them on the edge like that.  Perhaps GM needs to lower the opening temperature on them?  130-150F?
  • Thanks 1
