Spare tire lock
What’s everyone doing for a spare tire lock? Debating on just running a cable through to the frame and a weatherproof lock. I just don’t want it to rust and screw me if I ever need to use it.
My 2020 Silverado LT came with one from the factory. Are you sure your 2020 AT4 does not have one ?
Open up the little flap to the right of the license plate that the jack handle goes in and see if there is a keyed block off plate there. Mine unlocks with the metal key inside of the remote.
And the same bolt/cable cutter that they use to cut the factory cable will cut your aftermarket cable and/or lock.
If they want it bad enough they'll get it.
The same cordless cutoff tools and side grinders they are using to cut "theft-proof" bike locks will work on your truck too.
