Toggle switch location
  • 2 months later...
Pulls straight out.  Use a trim tool to pry it.  Not much room depending on the switch.  I was going to mount something there too.   The wires are there just held in place for the power outlet option.
I actually did this with my switch for a couple LED pods in the front bumper, where fog lights would be if equipped. You can remove the lower pieces of the center stack, and snake your hand up through to push them out. It's a tight fit, but I managed to do with without removing the whole surround and all that. I'll get a photo of the switch I put in later on today.
EDIT: found a pic. I did a ****** job of sizing the hole to mount it, so ignore that, but it's a good spot to mount one.
Edited by c.schill
16 hours ago, Julio13 said:
If wiring is there what would be needed to add the factory outlet?
It would seem like it would be there....they wire these trucks for everything, even if sometimes the option isn't there.
I may just have to call my dealership and find out.
  • 2 years later...
I want to do the same thing where did u pass the wires through? The firewall then the back of that center area?
