'Invisible' trailer camera calibration.
Maybe it's just me, but doesn't it seem like if you turn off your truck for something like fuel, that the camera system shouldn't have to recalibrate. I know the instructions say it has to do that, but seems to me that it really should add a feature to that says if the vehicle is turned off, then back on within a 30 minute period that it doesn't have to go through the calibration step all over again.
I'm loving the camera on my Airstream, but I find it certainly takes a bit longer than 60 feet to get it calibrated and sometimes getting it calibrated before you have to go faster than 25 MPH is impossible. Anybody else feel that they should have some storage of these values? At a minimum I would think the way to do it is try the previous values and see if the previous values are still valid.
-Wayne
You should have to only calibrate once as long as your profile is saved with dimensions.  If you change any dimensions or a camera, then you will need to recalibrate.  The calibration distance depends on a lot factors.  I have calibrated around a 100 trucks and never seen one calibrate under 1000 ft.  Calibration does not like shadows in the camera view.
#iworkforGM
#iworkforGM
Interesting.... I know my dimensions are saved with my Airstream profile. I wonder why it wants to recalibrate all the time?  It does look great though. I know I read something about it having to recalibrate... I'll need to go find those instructions now.
I have had it loose cailbration at fuel stops also, most of the time it figures itself out but not always. Other times I can pick the trailer up from storage and it recalibrates before i get out of the lot. I have been leaving the truck running during pit stops just to keep from loosing the calibration.
Interesting, @sdelam... that mirrors my experience.
So I just looked at the box that came with my camera.
Apparently the new part number is: 84946379
My camera part number is: 84876818
@MTU Alum: Can you tell me what has changed? Is there any updated firmware? Would the new camera behave differently?
  • 2 months later...
Hello. I am hoping someone can help.
I installed my camera and entered dimensions. The view is satisfactory to me but my camera wont calibrate. I have even taken a 15 mile drive. The furthest progress bar has gotten is about 1/8 the way. Any help? Is there way to force calibrate since I am satisfied with the view?
Thank you
I am having the same issue.  Installed camera and mounted dead center of target area. Set all dimensions and started drive to calibrate. Nothing in the instructions say you have to drive less the 30mph. It only says drive forward for at least 60ft. I drove over 50 miles today and it still is not calibrated. Camera is functioning great and have all views except invisible trailer. Any help would be great.
Poppop
It will only calibrate while going straight under 30 mph.  Find a place where you can drive at slow speed in a straight line.  It's ok to turnaround or make turns while calibrating.  The calibration can have issues if there are shadows in the camera view.  On sunny days, you can get shadows in the image.  Try going in a different direction.  I recommend selecting the transparent view during the calibration process.  There will be a yellow status bar at bottom of the view to see the progress as you drive.
#iworkforGM
16 hours ago, MTU Alum said:
You have to be under 30 mph to calibrate and it only calibrates when you are in a relatively straight line.  Did you mount the camera in the recommended area?  Which is basically center of trailer 2 inches above your tailgate camera with trailer attached.
#iworkforGM
Thanks for the reply. Yes, I found the side to side center line and mounted it about 2 inches about the height of the truck camera. I did do a long straight run for at least 1/2 mile at <30 and nothing. The calibrating finally times out and it does the transparent view.
Thx again for any assistance
