1 or 2" rear blocks for 2019 LTZ crew Z71
Can anyone verify that the 2014-2018 rear blocks will or will not work on the 2019's new body style? I am looking to raise the rear a little as my Ready lift level has put me a little nose high.
Thanks,
On 7/2/2020 at 8:31 PM, arvid.garey said:
Thank you very much!!
Can you confirm fitment? I'm looking to do the same thing... Same problem, the Ready lift put me just a tad nose high...
I want to ad an inch to the back of my LT, but don't know which block to buy. Correct me if I'm wrong, but I don't think my 2019 LT has a block in the back and all of the blocks I see are 2". With no rear block now, I don't need to replace a 1" with a 2" to achieve the 1" of desired lift (if that makes sense). If anyone has a link to a 1" block, I'd be grateful.
2015 SLT 4x4 stock blocks are 1-1/4" and will work with the new 2019's. I have my old blocks as described on my 2019 Denali with no issues. You will need longer u bolts.
Do you have composite leaf springs?  I don't think you can add a lift block to those springs.
Seems like it might! That's interesting news to me... I might have to remove the 2" from the front and get a set of Bilstein's instead!
