Similar Content
- 1 reply
- 3,524 views
- 2 answers
- 6,342 views
- 1 reply
- 3,261 views
- 0 replies
- 3,146 views
- 2 replies
- 6,341 views
Recently Browsing 0 members
247.6k
Total Topics2.6m
Who's Online 6 Members, 0 Anonymous, 1,921 Guests (See full list)
Question
Jeremy N Meagan Gardner
I have a 1991 Chev GMT 400 6cyl. It has approximately 175,000 miles on it . I recently have put a new starter ,water pump , fuel pump ,and battery in it within the past 2 weeks. Plugs, wires , and distributor cap and throttle ppsition sensor (i believe thats what its called) was changed about 2 yrs ago. However ,I've been having an ongoing issue with it that has been there since I purchased it and I can't figure it out. Whenever my truck is in idle it will sputter and stall out. It will sometimes sputter and stall in park . when I change it from park to drive, it will sputter and stall out every time. When I'm in drive and I come to a stop it will sputter and stall out ,unless I press the gas pedal too then it will stay running. Also when I'm in reverse and stopped it sputters and stalls out. Also I noticed if I'm in park and its running fine ,when I cut my wheel as far as it will go ,that will cause it to sputter and stall out. But like I said in park its very iffy , sometimes it'll run OK and sometimes it'll stutter and stall out. Other than that the truck runs fine as far as driving it goes and this sputtering and stalling out is the one issue I cannot figure out! I'm hoping someone out there knows what it is BC I have no idea and I'm hoping it'll be a quick ,easy and above all cheap fix . I bought the truck in 2017 and it had this issue , and it did sit for 2 yrs ,BC I used my car to get back and forth to work. But I believe I cracked or blew a head gasket in my car so I know that's gonna be an expensive fix. So after sitting for 2 years I decided to fix whatever it needed so I could get to work. And the things I had to replace within the past 2 weeks was the starter, water pump, fuel pump ,and battery. And also new tires . so hopefully I have given enough info to help y'all figure out what it could be . thank u for taking the time to read this and for your knowledge that you give to help me out. I'm not a mechanic ,so if you can , please be very specific on answers so that way I can know for sure what you are talking about . thank you!
1 answer to this question
