Ly6 to l96 swap running rich
The L96 injectors may be larger than your old LY6 injectors. The L96 is flex fuel so they are larger than the non flex fuel injectors.
Your fuel rail will be fine, just swap the injectors back.
Edited by CamGTP
I think I'm going to go ahead and try to swap the injectors. I've read this on other pages as well...mostly people theorizing. it's very hard to find any information from people that have actually done this swap. One other source I found was reporting problems with running too lean. My truck seems to run excellent. What's the worst that can happen if i keep running it this way?
If it ran rich all the time it will burn through way more fuel than normal and slowly kill the cat converters because of the extra fuel running through them.
I would say swapping the injectors will help a lot.
Edited by CamGTP
  • 8 months later...
Sorry I never updated. The injector swap fixed it. Ly6 to l96 was direct bolt in. Very easy swap just had to use ly6 injectors on the l96
