I have the AVS in channel ones and only the drivers side window is having issues with the pinch sensor.  Not all the time but only occasionally the window won't stay up.
I found that you have to be extra careful during installation and try to position them away from the glass as best as you can.  Also as another member said one of the back ones is slightly distorted from the glass forcing the visor out of its normal shape.
If it becomes a pain in the ass I may remove them and try another brand.
I just installed the EGR SLIMLINE and love them.  Front ones just slide into the channel and can be removed.  The rear have tape to secure into the channel.  Both sides can be install in less than 10m.  I wouldn't do the stick on.  I have zero issues.  EGR are thick and high quality and work perfectly.
