Passenger kick panel removal 2020 Silverado
  • 4 months later...
This is pretty simple, Pull off the cover behind the door handle with a small screwdriver or a pic, remove 7mm bolt. Pull off trim where the grab handle is. Start at the front and work towards the back. There will be 3 clips. Do not just pull it straight off as there is a plastic pivot twards the back. Once the 3rd clip is out open it like a hinge and slide it out. hen remove the 2 7mm bolts. Next, remove the 2 7mm bolts from the bottom of the door. Now, start at the back corner of the door and wiggle the door panel loose working all the way around the door. Pry tool makes it easier, but you can pull these ones loose if you dont have one. The key is that there is 2 more clips more in the middle of the door forward the door handle. Dont just pull on the door, just pull up a little from the bottom and wiggle and slide it tward the back of the truck. Those clips will slide off the door panel. Now just remove the harness and door lever cable and your good to go. Once the panel is off the truck, then you can pull those last 2 clips off the door without breaking them and put them back on the panel before you put it back on the truck.
    247.7k
    2.6m
    dakota98038
    dakota98038
  • Who's Online   2 Members, 1 Anonymous, 818 Guests (See full list)
