Apple CarPlay malfunction
Has anyone been having issues with Apple CarPlay mysteriously disconnecting? Then when you unplug and replug, it still doesn't work. But, after teh vehicle has been turned off and then restarted it works fine.
Edited by bradmo2723
Added more info
I’ve about decided CarPlay is not worth the hassle, it’s too buggy. Sometimes it works, sometimes it doesn’t. I’ve turned it off. The only time I’ll turn it on is when traveling and i want to use the navigation on my phone. I have a 2020 that i traded a 17 for and same issues in both.
I haven't had an issue with apple car play.  Are you using a true apple cord or using an aftermarket one?  I know in the past when using an aftermarket cord, I had issues with my laptop, etc.
As some have mentioned, get a factory Apple cord and do a hard reboot on the phone.  Cable choice is really picky with CarPlay.
Thanks for the response. I thought the same way, but even with the Apple cord, it’s still an issue.
Not just you OP.  Mine hasn’t worked day one.  Tried multiple cables that came with my iPhones over the years.  On iOS 13.3.1 my screen would stutter, freeze and not play music.  Updated to 13.4.1 and now the truck doesn’t even recognize the phone is plugged in.    It does charge though.
My 19 RST has done this occasionally since day one...The day we picked the truck up, it did not recognize my Apple SE. Dealer replaced receptacle plug (USB) but still happens occasionally, even if we are using the USBC plug..
Kinda quirky. Can't wait for a speeding ticket on the day WAZE is off line!
