2020 2500hd lowering kits?
Hey, I use my truck for work, which is concrete restoration, however most of my work is in parking garages. Height clearance is becoming and issue. I barely clear now, and there is lower garages I'll be working in. Anyone know anything on lowering kits for these new trucks yet. I need at least 2inches lower if not 4......any help welcome.
Edited by Leemmons52
Added info and pics.
The front is going to the hard part but the rear may be easy. Suppose you could crank the torsion bars down to lower the front some.
I've yet to look under a new 2020 model yet but if your truck has a rear lift block from the factory, you could remove that to lower the rear end some. Also look at the rear shackles. They made lowering shackles for the previous trucks and if they look anything like they always seem to do, I bet you could buy some of those and they get the rear end lower by 2 inches.
