Anyone put a Diamondback cover with headache rack on the new HD yet?
Just wondering if anyone on here has installed a Diamondback cover with the headache rack yet?  I am thinking about getting one but want to see some pics that show the height of the headache rack.  Specifically, I am hoping the headache rack is lower than the brake light and camera.  I don't want to order it and then find out that it is actually higher than the cab.  I have had Diamondback ATV covers before but not the headache rack.
I just finished installing a Magnum Low Pro rack with existing Bak Revolver X4.  I will probably reposition the anchors for the straps that secure the rolled up cover, from the cover to the second rail from the bottom on the rack.  They are just too hard the get the strap’s bayonet connectors into right now.
The Magnum top is above the camera and third brake light. It does not interfere with the camera view or the brake light.
Thanks but it is specifically the Diamondback that I am interested in seeing.  I can't put ATV's on any other cover.
I called them up to ask if the headache rack would interfere with the cameras and they didn’t have a definitive answer.
They just said there may be some loss of the field of view.
I am in the same situation that you are in. I would like to know for sure before ordering the headache rack...
Sent from my iPad using Tapatalk Pro
Even worse, I am in Canada and don't want to order the cover at all while they are shut down because the exchange rate is so volatile right now.  My luck, I would order it and the CDN $ will dip even lower when they finally decide to process my order.
