Leveling kit or AR-15 pistol build?
AR build.
Pistols are a blast, literally. What barrel length are you thinking?
I have a 10.5 and would not personally advise any shorter. Still uses a carbine length gas tube, but the dwell is short, so you compensate with a heavier buffer. Mine needed to be H2 config.
Let me know if you need advice.
Sent from my SM-J810F using Tapatalk
2 minutes ago, HeySkippyDog said:
AR build.
Probably a 10.5 Palmetto state
1 minute ago, HeySkippyDog said:
Going with a kit or sourcing parts one at a time?
I use PSA lowers, but I always source out the upper 1 part at a time.
My first build was a 16” kit so that was my plan
My tax dollars helped too. Do the ar. Lets be real here there are a ton of people whos tax dollars helped. There are a ton of people who dont need it. There are a ton who do. Let the person do what they want with it.
Edited by smrr1
  • Thanks 1
Here's mine.
Quick rundown of the main parts:
AR-Stoner A2 flash hider- SS
AR-Stoner 10.5" heavy profile barrel-SS
Spike's tactical BCG-M16 carrier
Aero Precision Upper receiver
Foxtrot Mike carbine length m-lok rail
H2 buffer
PSA lower built w/ PSA LPK
Standard carbine spring
Magpul MBUS sights
Blackhawk tactical ambidextrous, latch free CH
I will warn you. Using these short ARs will not make many friends at the range. They are LOUD!9ccd121161470484f9016036d129977a.jpg
On 4/19/2020 at 7:44 PM, onebohemian said:
Because some of my tax dollars helped to write you that check, and you obviously do not need it, how about you donate it to those who have no food to eat and are otherwise suffering.
Whoa buddy......My tax dollars wrote your check too.
