2005 Silverado 3500 dual tank delete
It should at least read to 1/2 full or so, as there are separate level sensors in each tank, and the bcm combines the sensor readings to come up with a "fuel level" for the gauge.  Maybe use a more advanced code reader that will show you the fuel level readings the bcm is seeing and putting out.
