'06 2500HD 4x4 trans filter removal
 Nope. You can do it without removing the X member. Need a shorty wrench and its a bit tight for 2 screws.
 I ALWAYS Re-USE the factory seal. Its thick rubber and has metal inside. This is far superior to a folded up paper gasket
and needs no sealer.
 I like to put on a much larger trans cooler too out front, fairly easy as well.
 Good luck !
You can also remove the transmission mount bolts and stick a jack with a block of wood under the transfer case, then jack the whole thing up an inch or two to give you more room.
Edited by CamGTP
