New here, as I just got a used '19 Silverado LD/LT 4WD. The General Grabbers that came on the truck are 255/70/17 and need replacement soon at 36K miles. I am installing a 3" front levelling kit and was told 275/70/17's should be a perfect fit with that levelling kit. Anyone concur and/or have that set-up?
Welcome! You are in the T1 forum, the LD trucks even though yours is a 19 are a K2 truck. You'll probably have better luck over there for answers. Anyway, congrats on the new to you truck.
Search around this forum, tons of information as that is the most common question asked.
https://www.gm-trucks.com/forums/forum/187-2014-2018-silverado-sierra-mods/
While your at it look up on that leveling kit. 3" is going to wreck havoc on your front end. The higher over stock you go the more issues it can cause. Going that high do it right with a suspension lift. Again, searching around the different threads and reading what others have done will be most beneficial. Take your time, you want to get it right. Many people jump in to mods and regret it by listening to a few quick responses to a thread they start that has been asked countless times. Load range, type of level, brand of lift, make of tire or type all play a huge role in the end result.
Tyler
Edited by amxguy1970
