slow speed suspension clunking
I'm having some issues with my brand new AT4. Just purchased a 2020 AT4 (2 weeks ago), had 24 miles on it. Within 100 miles it started making a clunking sound under the bed. Another 50, the steering started pulling and I had to take it in. Took it in and they tightened the u-bolts for the leaf springs which fixed most of the problem. The issue I still have is an annoying clunking sounds somewhere towards the middle of the truck, all the time. Happens at every stop sign, every turn, every speed bump. It's driving me crazy. The last time the dealer wouldn't even take it in. They said, "let us do some research before we bring it in." The suspension definitely doesn't feel like it did day 1, feels a lot "looser" and the clunking sound is tough to deal with.
Anyone having similar problems? Find a fix for it?
Thank you!
Thanks for the responses. I have the 6.2L. As I mentioned, they tightened the leaf springs, but there could be more to it.
As Davester mentioned, I just scheduled a service at a new dealer to have them look at it.
Kchampagne, let me know if that leaf springs fixes your issues.
Edited by Gthompson
My leaf spring squeak. I can spray lube on them at the plastic pads and that last a few days then starts squeaking again. Very frustrating pita. Dealer has looked at them twice and it’s the same answer. That oh we cleaned them and there’s nothing wrong.
They also want to give me shit because I installed Air Lift load lifter 5000 air bags. Smh.
My rear brakes keep intermittently squealing and they said because I had painted my calipers red that may be causing it. Horse Shit. My dealer sucks.
2019 Custom Trail Boss
When they re-torqued the bolts of the rear leaf springs at the dealer they were supposed to also install new rubber insets in the leaf springs. My truck was doing the same thing, after the repair the rear noises in the suspension went right away.
  • Thanks 1
My stealer looked at mine last week and said the inserts were the correct ones.
Said they cleaned between the leafs real good and it fixed the problem.
This weekend the problem returned.
I have Air Lift bags on the rear of my truck and they are giving me hell saying the bags are causing this issue.
I’ve added lots of air, taken all the air out, and had the pressure up to about 12 psi and various ranges in between and it will still squeak.
Every damn time I bring it in it’s not hardly doing it. I’ve found when it rains or there’s just a lot of moisture in the air, the springs tend to not squeak or not squeak that bad. I keep videoing when it’s bad but I guess that’s not good enough for them.
I’m sick of dealing with this shit and ready to just fix the shit myself.
They say I’ve technically voided my warranty because I’ve modified the rear suspension. SMDH
Screw it. I might as well go ahead and lift it more now.
My rear brakes keep squealing intermittently too and I’ve have videos of that as well.
  • Sad 1
Thanks for all of the responses, I took my truck to a second dealer, they confirmed that I’m just hearing play in the rear differential. They let me drive another AT4 around the lot, same issues. It’s just a clunky truck. Not sure how I missed it during my initial test drive. My last two trucks, 2019 Chevy Trailboss and 2013 F150 were quite a bit quieter.
Hey I just wanted to say please check out this other tread its seems these two should be put together.
This shouldn't be normal, I don't want a 50k clunky truck. Maybe we are all hearing the same thing but none of us nor the dealerships can figure it out. I can hear play in my rear axel as well by rocking the box side to side but that's not the noise I'm hearing in the cab while driving and if it is I will be very disappointed.
Thanks, Shawn Fox. That’s interesting, going to jump into that conversation. I thought the same thing, I definitely don’t want a clunky 50+K truck. That’s insane to me. Also, considering I just traded a 2019 Trail Boss, which I would guess has the same rear diff with no clunking sound, it’s hard to believe. I’m going to post on the other thread as well. I hope this is the issue and it can be fixed, can’t imagine keeping this truck for long with it banging around from even pulling into a gas station.
Also, good point about the play in the rear axle when you push on the side. I checked a brand new Denali, my old Trail Boss (that's sitting on the lot for sale), a used AT4 and a brand new AT4. They all do that, but I know my old truck didn't make this particular noise.
Edited by Gthompson
Based on jumping into the other thread that Shawn Fox linked above, I'm trying to find a shop that has chassis ears to narrow down where it's coming from. When my leaf spring u-bolts were loose, I could clearly tell it was coming from the rear of the vehicle. It felt as though the spare tire was loose and banging around. After tightening that, the remaining clunk is farther up in the vehicle. Frustrating.
