All lights 6 high/auto fog -DIY 2019 5.3 Silverado
12 hours ago, Chrisj4 said:
I’m assuming these are the same for a custom. I had the fog lights put in by the dealer and for some reason I can’t get the diode to insert into pin #10 (the wire they installed with the fog light setup seems slightly thicker than the rest). This is the second night in a row I’ve spent around an hour trying to get this done... Any tips out there to help me out? ?‍♂️
Hey get the boost auto parts mod. They have a couple different ones. They work with wire taps.
here’s a link for the auto fog lights mod.
https://boostautoparts.com/products/1999-2020-gm-auto-fogs-mod
  • Thanks 1
On 3/18/2020 at 9:36 PM, Rado5.319 said:
This diode installation allows all of the lights to remain on simultaneously when the high beams are activated on GM vehicles. The diode is super easy to install, you need $2 and 10 minutes. 9 of those minutes will be spent congratulating yourself.After diode placement your lights will function as follows:
  • In auto mode- whenever your lights come on automatically the fogs will be on also.
  • Low Beams & Fogs- Only Low Beams & Fogs will be on
  • High Beams- Low Beams, Fog Lights, & High Beams will all be on (normally by default)  The vehicle turns off the fogs when in high beam mode, but this diode solves that.
  • MAKE SURE THE SIDE OF THE DIODE WITHOUT THE STRIPE IS IN THE 10 PIN. The diode allows electricity to travel in only one direction.
With this are the fogs suppose to come on with the daytime running lights
Edited by Gerstein1989
  • 6 months later...
On 5/24/2020 at 2:27 PM, EXSlider400 said:
EXSlider400,
Thank you very much for the information. I appreciate your willingness to share your knowledge. I didn't know I wanted to do these mods until I read your post! I was hoping you could answer a few questions for me?
2020 Sierra 1500 SLT
Foglights to DRL - could you share the plug/pin numbers and which way the diode goes?
Cargo lights w reverse - same. Plug/Pin numbers/diode direction please?
I've got the 1N4001 diodes in my Amazon cart. Those are the correct ones needed to accomplish these mods, right?
Thanks again for your help!
Daryl
  • 4 months later...
  • 1 year later...
