- 0
Electrical problem, blower speed selector causes abs and brake lights come on.
Similar Content
- 1 answer
- 219 views
- 1 reply
- 381 views
- 41 replies
- 3,159 views
Diablosport inTune i3 8246 Platinum Tuner - $350 Shipped
By erodriguez24,
- diablosport tuner
- Silverado
- (and 3 more)
- 0 replies
- 739 views
- 3 replies
- 581 views
Recently Browsing 0 members
247.2k
Total Topics2.6m
Who's Online 19 Members, 0 Anonymous, 1,962 Guests (See full list)
Question
mitchmxz
I have an 04 gmc Sierra Wt with a weird issue.
it started when my battery went bad. i use the intermittent pin in the body-12 way-brown in the cab fuse block as an ignition driven accessory.
the first thing i noticed was the accessory would only work every now and then.
next the blower stopped working, the abs and brake likes came on, all at the same time.
after messing with it all day here is the current issue.
the abs and brake like come on when the blower speed control it set to any speed other then 0. when set back to 0 the abs and brake lights will turn off.
the intermittent pin on the body-12 way-brown has low voltage and cant power my accessory.
the constant power pin next to the intermittent pin has full 12 volts.
I have checked every fuse and cleaned the ground on the forward driver side and the ground in front of the driver side suspension.
I have also added 3 ground wires
cab to battery
frame to battery
block to battery
I am at a lose for what to do.
Could it be a bad relay?
4 answers to this question
