Cruise set to “” message.
I'm just wondering if everyone else is seeing this message. Every time I set or change the cruise MPH I get this message.
Small problem (if that) just wondering if everyone else's truck works the same....
The message is normal - just letting you know cruise is set and at what speed.  I only see it once when I set cruise on.  As said above you can answer OK or let it time out.
If you use the little paddle on the left side of the steering wheel - does the message reappear with the new mph you set ? Mine does.
Guess I can deal with it. I was hoping it was something I could get rid of.
Yes, a speed change confirmation will show on the dash.  It's momentary and goes away in a few seconds.  Not driver action is required.
