Bouncy Front End Suspension
I have a 2017 Silverado WT and the front end suspension seems weak. It seems to me that the coil springs over do the stock shocks on it. If I go into my driveway , even at slow speed, it bounces like a pogo stick.
My 2002 Silverado never did this and it had 110K on it. This 2017 only has 15 K on it.
Has anyone else experienced this?
I don't really notice that with mine. This is my 3rd truck with front struts so maybe I'm used to it. It's not exactly a smooth truck around town with our crappy roads here because of winter but it is a truck.
Your 2002 used a torsion bar suspension with a separate shock if it was 4X4 and 2WD's had a coil spring with a shock so the ride is for sure going to act different than a strut assembly.
Same here, wish I'd changed the front shocks as soon as I got it. Bilstein 5100s made a huge improvement to the crashing over speed bumps issue I had from new.
I'm sure you can improve even further if you want to spend the coin.
2014, 5.3, 4x4, work truck
  • Thanks 1
