7 Pin Connector with 3 Pin Camper
Hi All.  I have a camper that just uses Ground, 12V, and Running Lights.  When I wire these into a 7 pin connection, it doesn't recognize it when plugged into the 7 pin outlet on the bumper.  I have tried adding as an accessory but it says "No trailer connected".  Anyone have any luck doing this?
You need a Putco harness. its a 4 pin connector but it doesnt connect to the trailer app so you can add what ever adapter you need.
https://www.amazon.com/529005-Connect-Harness-Silverado-Sierra/dp/B07V82RZNT
Looks like if you hook this up to the 7 pin it thinks there is a trailer attached and gives me the functionality I want.  Not sure if it would screw something up in the long run, but it has built in resistors to make it seem like something is attached.
https://www.amazon.com/gp/product/B00C4AYR3U/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
When I plugged it in the trailer screen popped up as seeing a trailer there and asking which trailer profile to use, so yes it seems to work that way.  Gonna take it for a ride and see if the cameras pops up on the turn signal activation.
22 hours ago, hkyfsh said:
Took the truck out today with the adapter plugged in.  It asked for a trailer profile and if you select one then the cameras activate on the turn signal.
That’s awesome!
