my 6.0 with 230xxx has low oil pressure but no knocks maybe a little tick though. When i bought the truck it had maybe 5-9psi cold dropping to 0 warm. Thought it may have been a pickup tube oring or oil pump so i went ahead and replaced the pickup tube, o ring, and pump. it now gets 20 cold 7 warm at idle and 0 warm at idle and 20 warm running 1700 rpm. Which is a lot better but still a problem. I am aware the bearings may be shot and need a total rebuild, that is not out of the options. It is not electrical or sensor based issue same psi with a mechanical gauge. However I need to replace my harmonic balancer and take off the timing cover again so i was looking at it and could it be as simple as a o camshaft retainer plate? it has a build in thin o ring which if fails will drain pressure as it connects the oil gallys. Am I correct in thinking that this could solve my issues? Any input is helpful, thanks.
  • 4 years later...
