Vasa1 Posted February 3, 2020 Share Posted February 3, 2020 Has anyone changed their cabin air filter? I can remove the glovebox but on the left side of the box there is some sort of pivoting lever. Quote Link to comment Share on other sites More sharing options...
BlancoSilverado Posted February 3, 2020 Share Posted February 3, 2020 Yes, you drop the glove box down, you can remove the small "shock" by disconnecting it on the left side. then there is a flat panel that comes off and the filter is right in there. make sure the arrow on the new filter is pointing down. I had a mold smell. Quote Link to comment Share on other sites More sharing options...
Vasa1 Posted February 3, 2020 Author Share Posted February 3, 2020 Guess I should have specified that I have a 19 Sierra. That shock u mentioned, is there a certain way it goes back in? Quote Link to comment Share on other sites More sharing options...
BlancoSilverado Posted February 3, 2020 Share Posted February 3, 2020 16 minutes ago, Vasa1 said: Guess I should have specified that I have a 19 Sierra. That shock u mentioned, is there a certain way it goes back in? i totally forgot, I know that you only need to un-clip it on one side(bottom) you can use your fingers to press the clip together to release it. Quote Link to comment Share on other sites More sharing options...
HapaTrailBoss Posted February 4, 2020 Share Posted February 4, 2020 If you accidentally pulled the damper apart like I did (doh), it easily reattaches, you just have to align the black circular clip and push. After 20k miles and 12 months of use, my cabin was filthy. Quote Link to comment Share on other sites More sharing options...
BIGDOGx Posted February 4, 2020 Share Posted February 4, 2020 20 hours ago, HapaTrailBoss said: If you accidentally pulled the damper apart like I did (doh), it easily reattaches, you just have to align the black circular clip and push. After 20k miles and 12 months of use, my cabin was filthy. Yeah only takes like a year and the thing gets pretty bad, i only put around 10k a year on my truck too so those of you with 25k on the clock with a year old truck it's time to change it imo. Quote Link to comment Share on other sites More sharing options...
