Trailering with a 2019 Silverado LTZ 4wd
3 hours ago, f35rocket said:
Has anyone found add on towing mirrors for the new body style? Also, has anyone added trailer tire pressure monitoring sensors? Are they the same part number as the truck ones? Do they work well?
There are clip-on tow mirrors specific to the 2019 now available.  The trailer sensors are different from the truck tire sensors.  They should have come with your truck.  If they didn't, either the dealer kept them or you don't have the advanced trailering system.  If you don't have the advanced trailering system there is no way to add it after market.  It is not a plug and play setup.  But since you have an LTZ, you should have both the advanced trailering system and the sensors.  Check your glove box or the center console.
Edited by AlaskaErik
10 hours ago, f35rocket said:
Thanks for the info Erik. I do have the max tow package, so I'll ask the dealer what happened to the sensors.
Max Trailering Package is different from the advanced trailering system.  Your LTZ should have the advanced trailering system, as I believe it is standard on LTZ and High Country trim levels.  Max Trailering is an option on the LTZ.
