What have u done to your 2020 hd
  • 1 month later...
On 9/13/2020 at 12:11 PM, sealberta said:
It's just a switch.  It interrupts the center tailgate switch so it won't drop down on the trailer hitch when it is installed.
Can you show which wire that you "interrupted"?
I did this mod as well but used a water proof toggle switch down at the receiver. You tie into the solid purple wire that’s in this connection under all the tape under the bed of the truck by the bumper if not mistake I’d have to look to see exactly where it was located.
On 1/15/2022 at 2:37 PM, Trinity2020 said:
I recently added a pair of Fuel "Diesel" Wheels and Mickey Thompson 35x12.5x20 ATZ's to mine. 1.5" level I did about a year ago.
Which 1.5 level did you use and did it affect your ride quality? TY
On 3/23/2021 at 6:53 AM, doozer78 said:
3" superlift. 1.5" rear blocks. Differential spacers. 22x10 vision wheels. 22x12.5 tires
-19 offset. 129f1bfea99b7e6339f6128c382e7e10.jpg6b821a5ca9fdfc40d184b8caaef6180b.jpga357b4e48e97241616a4945a02cca4aa.jpg85b0343b306596d7df4841a4fe90daea.jpg
Sent from my SM-A705U using Tapatalk
I just posted a question on a very similar set-up.. Are you running 35's on this? If so, how much trimming did you have to do and does it still rub? I have 35's on 22" Fuel Blitz with a -18 and it rubbed really bad.. Looks great by the way!
  • 4 weeks later...
On 5/6/2020 at 7:24 PM, jackedupZ71 said:
Picked up a 2500hd with a 6.6 gas motor monday, got home just before some severe storms hit. Turned the bars up about 3 turns each(1 1/4” per side) and had 35x12.50 Toyo RT’s mounted today. It still has a slight rake to the rear, but once I get my pack rat, montezuma, and air compressor in the bed it will sit level. ea25c40a1b3ea444e49c745e9c869e9e.jpg
What do you mean by "Turned the bars up about 3 turns each(1 1/4” per side)" I am new to the truck world (traded in my 2017 Suburban for a 2022 Silverado 2500HD LT Z71).
