Mazzulla Lift Spindles 14+
BIGRED811
MZS-C2-3
Had these before I received the truck and ended up going a different route. They are brand new in the box with all included hardware, brake lines etc. Currently these are not available from Mazzulla at the time, they were priced at $1599.00 Looking for $1,100 OBO
  • CAD designed and engineered
  • Manufactured in the USA
  • 2" Solid machined hub mounting blocks
  • High strength fabricated construction
  • MIG and TIG welded
  • Provide 3.5" of lift and ground clearance
  • Includes steel braided brake lines
  • Powdercoated finish
  • For use with cast steel control arms only
  • For use on 2wd trucks only
  • Maximum wheel backspacing is 5"
MZS-C2-1_3.5_Inch_Lift_Spindle_b91ba708-4b7b-4353-bde7-7c012fae1d75_530x__97444.1496276266.jpg
Upper_Arm_And_Spindle_Installed_62e835c2-a681-4c93-afa7-2139328be350_1024x1024__18790.1533081488.jpg
Edited by BIGRED811
