Do I need/want Hill Descent Control?
On 1/19/2020 at 11:00 PM, FirstAscent said:
Hey everyone, so I recently placed an order for a 3500 high country duramax and did not choose the z71 package which includes hill descent control. Apparently you can only get it with the z71 pkg.
In order to choose that package I would have to remove the interior convenience package which has the all weather floor liners and rear under seat storage I wanted.
Does anyone have this feature that thinks it’s amazing or anyone not have it and wish they did?
Just want to make sure before it’s too late to make changes to my order
That's interesting.
On 2020 Silverado 3500 it's shows as optional all trims, and requires Z71.
On 2020 Sierra 3500 it shows as 'included and only available with X31 on base/SLE/SLT trims.
But it's standard on 2020 Sierra 3500 AT4 and Denali (and not available on dually Denali)
I've had vehicles with it, have read the description of how it works.   Haven't yet found a place where I needed/wanted it.
Of course there must be those out there that can and do use it.
You can download the 2020 sierra and/or silverado owners manual from GM website if you need details about how it works to assist your decision.
Interesting indeed. I would’ve thought it’d be similar between Chevy and GMC.
Another interesting thing about the Z71 package, when playing with build options on a 3500 High Country, if you select the Z71 package, the pop-up only states it is adding:
Skid Plates
And not the other typical features such as off road suspension, badges etc. whether that’s accurate or a typo, I have no idea default_smile.png
However, just tested a 2500 build, if you select the Z71 package on that model then it DOES list off-road suspension as included as well.
Could be due to the extra payload/leaf springs in the rear
Skid Plates
And not the other typical features such as off road suspension, badges etc. whether that’s accurate or a typo, I have no idea :)
Order guide shows different add-on depending on the trim.  Pop-up in 'build and price' should also change depending on what trim level is being used.
Z71         Z71 Off-Road Package, includes (Z71) Off-Road suspension with off-road tuned twin tube Rancho shocks, (JHD) Hill Descent Control and (NZZ) skid plates (transfer case and oil pan)
On work truck- Requires 4WD model. "4X4" decals on bed are replaced with "Z71" fender badge. Not available with dual rear wheels or (ZW9) pickup bed delete.
On LT - Requires 4WD model. Includes molded in color grille with Z71 logo. Included with (PDZ) Z71 Off-Road and Protection Package. "4X4" decals on bed are replaced with "Z71" fender badge. Not available with dual rear wheels or (ZW9) pickup bed delete.
On LTZ - Requires 4WD model. Includes Chrome grille inserts with Z71 logo. Included with (PDZ) Z71 Off-Road and Protection Package. "4X4" decals on bed are replaced with "Z71" fender badge. Not available with dual rear wheels or (ZW9) pickup bed delete.
On HC - Requires 4WD model. Not available with dual rear wheels.
That makes sense, thanks for the additional info. Also makes sense it’s not available for the dually
Just pick the other package then add the floor mats....
Sent from my Moto Z (2) using Tapatalk
Well I originally thought I wanted the under seat storage which you can apparently only get with the interior convenience package.
But I recently learned that THAT under seat storage is the larger plastic under seat storage. I have that on my ‘19 1500 and actually don’t care for it, and it feels cheap. I think I prefer the normal carpeted but smaller under seat storage.
So yeah I could’ve just chose the z71 and add the z71 floor liners separately as you mentioned.
I think that there should be an option for Z71 off road and protection package. I thought it brought all the Z71 stuff, and the all weather floor mats and spray in liner.
There is 2 z71 options that one makes it so u can't have a few packages
I picked the z71 package that gives u shocks, skid plates and hill decent
I did the z71 for the suspension and skid plates
As far as the title of the thread the hill decent isn't all that great depending where u drive ...I've used it 5 times in 5years on my 15
i don’t have it.  i did come down from 6500 to 4000 feet on a steep, narrow north Idaho forest road in 8” of snow this year.  I put z chains (cables) on all four tires and used 4 LO and the manual shift function on my 6L90 to control my speed.  I could see how it would have been nice to have, though.  Hours of that stuff can wear you out mentally!
  • 1 year later...
The “off road suspension” is simply the Rancho shocks - no other suspension changes.
Read the owner’s manual on line for a more complete description of how hill descent control works and its speed ranges in high and low transfer case ratios.  I have it and have tried it, but I doubt I’ll use it much.
