davester Posted January 19, 2020 Share Posted January 19, 2020 1 minute ago, Stevie said: Its an electric water pump. I think there is no thermostat neither, its like a chamber that pivot and open and close to divert the coolant, either to warm up the engine and transmission oil or to the rad. It seem like a complicated engine setup! My goal is to keep it for decade... lol. I'll be fine with all the global warming happening! I would suggest harassing GM about it,if it's not heating up the cab well. Otherwise, it's NBD. Quote Link to comment Share on other sites More sharing options...
OnTheReel Posted January 19, 2020 Share Posted January 19, 2020 I’m assuming the electric water pump is set up to run on demand only. If it’s idling in the cold, it’s probably programmed to not circulate as much, in order to speed engine warmup and maintain the temperature. The side effect of that would be...it’s not circulating coolant through the heater core either? Seems a bit short sighted on GM’s part if that’s all there is to it... Quote Link to comment Share on other sites More sharing options...
Chris Nickel Posted January 12 Share Posted January 12 On 1/17/2020 at 3:36 PM, Stevie said: I wonder if it's normal that my coolant temp gauge stay that low after 30 minutes of idling on freezing temperature. Engine is a 2.7 turbo 4 cyl. -21c/-6f. I'm also in Edmonton and my 2023 is doing the same. Seeing as you posted in 2020 what was your outcome? Quote Link to comment Share on other sites More sharing options...
davester Posted January 13 Share Posted January 13 ...probably won't find out, as Stevie hasn't logged onto the site in 4 years... Quote Link to comment Share on other sites More sharing options...
silveradosid Posted January 13 Share Posted January 13 my 2020 is the same, all though i do not idle it much but i have a few times. i think it is because the cam is in low lift mode and only so much fuel can be delivered in that position, which is why i don't idle it much. remote start for 2 to 3 minutes and i am gone. it heats up faster driving it Quote Link to comment Share on other sites More sharing options...
