Rear axle shaft seal removal question
I recently removed the rear bearings & wheel seals. In the process of removing the bearing I was hammering the inboard seal which the axle shaft rides on. I had little room to hammer out the bearing bc it was sitting next to this seal. I assume this inner seal that the axle shaft seal is not supposed to be removed? It wouldnt move when hammered on. I could be wrong.
My concern is that this I damaged this seal. I have no clue where to order a new one.
I called the local autozone and they said all they had was outer wheel seals. I figured that's all there was. Apparently not on a 2009 Chevy Silverado 1500 2w drive.
Edited by Ethan Schneider
Add more info
