- 0
Check Engine Codes P0443 and P0458
Recently Browsing 0 members
247.8k
Total Topics2.6m
Who's Online 17 Members, 0 Anonymous, 2,610 Guests (See full list)
Question
Bryan Hughes
Hello forum folks, I apologize in advance for what I'm sure is an easy answer, but I'm about to lose my mind. I purchase a 2015 GMC Canyon (3.6L V6 All Terrain) last weekend. One day out a check engine light came on, it was the gas cap not on tight. The technician at the dealership didn't put it back on right when I bought the truck, my bad for not checking. But the next day I get two codes, P0443 and P0458... As a former Ford Escape owner, Im painfully familiar with the EVAP purge valve needing to be replaced. But I couldn't believe something like that would go bad so quickly. After all, I just bought the truck two days prior...
Anyways, to error on the side of caution, I purchased a new EVAP purge valve and installed it myself. I'm sure most people on these forums would agree its pretty easy.
So almost a full day goes by with no light, then as I'm driving home from work, there they are AGAIN! The same two codes... I have a code reader, so I clear them. Drive ten miles, BOOM back again... I even tried disconnecting the negative post from the battery to do a hard reset. That seemed to work, took the truck for a small drive, turned her off, then when I started it back up, there's the check engine light with the same two codes again. So at this point I'm at a loss and desperate for any advice that would help keep me from having to take it in to a mechanic. Please and thank you!
Edited by Bryan HughesLink to comment
1 answer to this question
