Leaks around overhead light panel
I have experienced some leaking around my overhead light panel during a heavy rain storm. The water dripped onto my center console and has stained the headliner. Any ideas on how to fix? It's a 2016 Silverado 2500HD Z71 package with 70k miles.
This has been mentioned many times before and I had this happen to my 2016 Crew Cab. You most likely have a leak coming from your shark fin antenna. When mine happened, they replaced the antenna under warranty with a new one that was supposedly redesigned. This was done about a year ago and so far, no more leaks. But even the replacement has come with mixed reviews with some having the leaks return.
Even if shark fin appears to be solid, it still probably has a leak around the gasket. You will probably have to remove the headliner to access the mount for the shark fin.
Edited by mikeyk101
