Coil overs for 2019 at4?
Hey guys, the Fox coil overs are through BDS, even though it’s basically the same company not all parts show up on the Fox factory site.
Here you go, order away!
http://bds-suspension.com/product-display?all
Chevy/GMC -> Shocks/Coilover tab -> click on View Fox 2.5 series green button
This is to order separately, or you can order with the BDS lift kit.
Hope this helps!
6 minutes ago, Joel553 said:
How are they on road? What about offroad? Im between king and fabtech coilovers. Thanks.
They run great. Went to big bear last week and hit some trails. It felt really stable. I highly recommend the kings
Did you have to do anything to the upper control arms? I know fabtech includes a new uniball control arm when you buy their coilover kit.
I replaced the stock UCAs with Bajakits UCAs
https://camburg.com/vehicles/2019-1500/
I don't see trail boss or at4 but am sure they have something, maybe
https://camburg.com/shop/suspension/camburg-chevygmc-1500-2wd4wd-2019-king-2-5-performance-kit/
this one has TB
looks like king has em but fox is out of stock thru camburg
Edited by Dunn
I talked to JT I probably head down to bajakits this week.
there is a guy selling an ICON kit on here, he pulled them bcuz he going to 2500 HD l believe, I forget his name but saw it other day if anyone looking for
Edited by Dunn
Hope this helps!
Thanks for the link. How are you liking the setup so far?
Sent from my ONEPLUS A6013 using Tapatalk
I have (had) Icons on my truck not Fox. I was just providing the link to help :) however, loved the Icons!!
I started off with the original BDS lift kit and rear fox shocks, leaving the stock front Ranchos as the coilovers were not available. The overall ride quality of this setup was fine, but you could feel inadequacies of the front Ranchos. The rear fox setup was firmer, and it accentuated the 'squish'ness' of the Ranchos.
Replacing the front stock setup with the Fox Coilovers is night and day better. I've set them full soft to full firm (LOW SPEED SETTING). Currently have them set 4 notches off of the firmest setting.
Full soft is much more composed then the stock Ranchos. There is very little brake dive and sway, but still a very comfortable ride.
Full firm  is not overly aggressive, but will allow you to feel the road much more. For daily driving, it's a bit excessive, mainly because I felt the need to drive much faster then the law allows.
3 off of firm was fantastic, and I will probably switch back to it for daily use. It provides all the comfort you'd want, while leaning a bit more towards performance.
4 off of  firm is also fantastic, putting the bias towards comfort vs. performance.
However, the front is far outshining the rear setup at this point. The rear Fox shocks are a fantastic upgrade over the OEM (which I couldn't imaging having with the front coilover setup), but sitting on 5" of block is just not going to cut it. I would venture to say, if the rear lift was coil based, I'd probably stop, as the rear shocks are more than adequate.
So, next up is a new leaf spring setup and adjustable rear shocks, still talking with my shop, so we'll see how it goes...
Thanks for the reply. I think this will be the way i go once i get mine lifted.
Have you looked into deavers for the rear? I think besides having someone do a full coilover or air bag conversion it might be the best bet.
Yes. Deaver said they have only done a 2" so far, but, it wont be an issue. Going to take about 4 weeks to build. I'm currently looking into adjustable rear shocks, too, although I may just do the deavers and see how I like it first.
