Off road lighting wiring questions?
This is for those that have already added off road lighting accessories to your 2019/20 Silverados.
Where did you get power for your lights? Did you connect directly to the battery or did you find a power source that runs off of the ignition? Did you run switches inside of your cab?
Any info would be helpful for those of us that are new to adding after market lighting systems. Photos of the correct wires would also be helpful.
I am gonna do an install in the next few days, (a bit under the weather), I have already hooked up a second battery and a fuse box off that. I am gonna go from there and as far as running power for a switch into the cab I am still looking for ideas.
