2014 Sierra 1500 Rim Type
Good afterenoon, and happy new year to everyone.
I have a issue that I cannot seem to nail down.  I have a rim that is leaking air at the bead with new tires.  I've been told that the rims needs to be replaced. My issue is that I cannot locate the rim/style/design of what exactly it is to find a replacement.
The stealership offered up a $576 rim, but seriously, that's seems out of control.  I'd be happy to use an aftermarket replica or go to the junk yard and pick up a used one.  attached is a pic of the rim, but I cannot find any specs to use other than the dimensions.
Can anyone tell me the style, name or design of this rim?
Rim is 20x9, factory (I believe it is listed as "design 3").
2014 GMC Sierra.
275/60/r20's.
Think they're referred to as "honeycomb" wheels  There are 2 different wheels with nearly the same pattern...one is like the picture you posted with the flat on the "fork" (honeycomb type) while the other has more of a "Y" shape (snowflake type).
I believe this would be the one you are needing (double check first though).  Can't tell if yours is chrome and is dirty or if it's machined
https://www.elementwheels.com/wheels/replica-wheels/gmc-sierra-replica-wheel-silver-machined-face-fr44/replica-fr44sil2090
Edited by dsr611
Check LKQ they have a decent selection of refurbed wheels. Not sure where your located, but Detroit Wheel is also a good place to check for a refurb. There's also Performance Replicas I believe they make this wheel and it will be half the price as the dealer. Only issue is the center caps are usually a different diameter.
Sent from my SM-N975U using Tapatalk
I had one get slightly damaged from a flat tire, and replaced it with a factory one from someone selling takeoffs on Ebay. It was a while ago now and I paid a smidge extra to buy 1 and not the full set, but it was still better than going to the dealer.
OEM wheels are all over for the K2s, there's no shortage especially with the designs that were present from 2014 and on. Just look around online.
Sent from my SM-J810F using Tapatalk
I'd watch for new full set of take-offs and sell my three good wheels to people facing the same situation as you.   The only problem with my idea is I think your wheels are the nicest offered since '14!
