Grumpy Bear Posted August 5, 2020 Share Posted August 5, 2020 37 minutes ago, dieselfan1 said: Oh my Looks good Grumps Sent from my Pixel 3 using Tapatalk That particular part is rubberized but was the dullest and easiest to photograph. The hard plastic parts like the door handles actually came out better but for some reason the difference doesn't photograph like the experience. Quote Link to comment Share on other sites More sharing options...
CovetedStyle Posted August 5, 2020 Share Posted August 5, 2020 4 hours ago, Grumpy Bear said: Awesome 1 Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted August 6, 2020 Author Share Posted August 6, 2020 Got a new trailer so I need to do the axle flip( put the axle under the leaf springs instead of on top of them) because my driveway is steep and it would drag bottom if I don't put some boards down. I've done this a few times now for the same reason. It should raise it about 4 1/2 " . I'll take some pics to show you what I do. Here's how it sits now. Looks more level than it is. Pics do that sometimes. [emoji3166]I Sent from my Pixel 3 using Tapatalk I got it done yesterday , very easy job.Pull the tires, loosen up the U bolts, pull axle out and put it under the springs. They make a new perch that sits on top of axle and rests on the original perch. Just square or all up then replace U bolts and plates with new ones and put tires back on.Then I took it over to my buddy and had him weld the new perches and the big nuts that sit on the old perch. Done.Sits exactly 4.75" higher. Sent from my Pixel 3 using Tapatalk 4 Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted August 21, 2020 Share Posted August 21, 2020 On 6/19/2020 at 12:37 PM, dieselfan1 said: Here's the hitch. I think I need to get some braces to stabilize it. That photo I promised you. Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted August 21, 2020 Author Share Posted August 21, 2020 UffdaLot going on there but thats what I need . The more I tow with it like it the more I dislike the setup. I need to get something like this[emoji106]Sent from my Pixel 3 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted October 28, 2020 Author Share Posted October 28, 2020 Not too happy this morning. Truck no start. Had to jump it. Put new battery in it good to go .I replaced the Delco 720 cca with a NAPA Legend 790 cca.Can't hurt to have a few extra when it's -30 in January. It's only two years old this month,(10-18).But the truck was built in 8-18.WTF?I'm thinking since this truck was a leftover that I bought 12-15-18 , the dealer had to put a new battery in it because the original was bad and it wouldn't start. Make sense?Sent from my Pixel 3 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Frankielozano214 Posted October 29, 2020 Share Posted October 29, 2020 16 hours ago, dieselfan1 said: Not too happy this morning. Truck no start. Had to jump it. Put new battery in it good to go . I replaced the Delco 720 cca with a NAPA Legend 790 cca. Can't hurt to have a few extra when it's -30 in January. It's only two years old this month,(10-18). But the truck was built in 8-18. WTF? I'm thinking since this truck was a leftover that I bought 12-15-18 , the dealer had to put a new battery in it because the original was bad and it wouldn't start. Make sense? Sent from my Pixel 3 using Tapatalk Man it’s been cold over here, almost had a no start yesterday too, it sounds sluggish. Might buy a new battery 2 Quote Link to comment Share on other sites More sharing options...
CovetedStyle Posted October 30, 2020 Share Posted October 30, 2020 On 10/28/2020 at 11:37 AM, dieselfan1 said: Not too happy this morning. Truck no start. Had to jump it. Put new battery in it good to go . I replaced the Delco 720 cca with a NAPA Legend 790 cca. Can't hurt to have a few extra when it's -30 in January. It's only two years old this month,(10-18). But the truck was built in 8-18. WTF? I'm thinking since this truck was a leftover that I bought 12-15-18 , the dealer had to put a new battery in it because the original was bad and it wouldn't start. Make sense? Sent from my Pixel 3 using Tapatalk I hate it when that happens! 1 Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted November 2, 2020 Author Share Posted November 2, 2020 Pulled the trigger on a pair of spacers today. It's always bugged me after the lift that the front track was 2 1/2" wider than the rear. Even stock there is about an inch difference if I remember. The McGaughys has 7/8" spacers on the axles. I order a pair of Stahl 1" steel spacers. Same company as BORA. I could have got 1 1/4" to make it exactly the same as the front but 1/4" is not going to matter. 2 Quote Link to comment Share on other sites More sharing options...
CovetedStyle Posted November 3, 2020 Share Posted November 3, 2020 Very nice! I‘ve been thinking about picking some up. Can’t wait to see yours installed! Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted December 4, 2020 Author Share Posted December 4, 2020 More stuff on order today.I ordered a set of Longhorn Fab Shop traction bars. The axle wrap issue has always bugged me .I've never really floored it from a dead stop since I installed the lift because I know with a six inch block, it has to be " not good" for anything.2" diameter, 72" long. Stout setup. Problem solved. Still waiting for the spacers.[emoji19]Sent from my Pixel 3 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted December 4, 2020 Author Share Posted December 4, 2020 I always liked this picSent from my Pixel 3 using Tapatalk Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted December 12, 2020 Author Share Posted December 12, 2020 I ordered a GM accessories Kicker subwoofer today. Got it for $527 or around$175 less than the dealer. Ordered it from Shop Chevy Parts.It should make it here for Xmas.So I got 3 presents under the tree. Traction bars, spacers, subwoofer.[emoji319] Sent from my Pixel 3 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted December 12, 2020 Author Share Posted December 12, 2020 While I was at it, I ordered some new door speakers.Kicker from Crutchfield.Now I got a full day of work installing all of this in the next few weeks.I'm looking for a significant improvement but I'm not expecting to shake it like I have 2-12" subs. Sent from my Pixel 3 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
dieselfan1 Posted December 13, 2020 Author Share Posted December 13, 2020 Im thinking I might have made a mistake with the subwoofer I ordered after reading through a bunch of posts. Here's what I discovered....The stock speakers are junk.They are paper. The bose speakers are exactly the same. Bose uses a digital processer to improve the sound quality using the same paper speakers.They are made to sound decent with the stock radio. Changing to better quality speakers will not help because the stock unit don't have enough watts. So you need an amp on your stock radio to give the door speakers more power they were designed to work with. Then the difference is night and day although some amps make the door chimes and turn signal super super loud. I'm pretty sure the GM Kicker with separate amp setup don't do that. It has a separate 200 watt amp for the door speakers and a 200 watt amp in the subwoofer. I think I'm going to order that one and cancel the order for the basic setup.Sent from my Pixel 3 using Tapatalk Quote Link to comment Share on other sites More sharing options...
