L5P Oil Life Monitor mileage?
Curious what everyone is getting for the OLM mileage on an L5P?
I know I drive alot as I'm over 25K in just over a year, but it seems like I'm constantly having to change my oil.
DATE MILEAGE OIL VISCOSITY OIL OIL  % FILTER RECEIPT MILES/OIL CHANGE
12/14/18 2785 5W40 MOBIL DELVAC ESP 38 K&N FF#1 2785
02/21/19 6308 5W40 MOBIL DELVAC ESP 29 K&N FF#1 3523
06/04/19 12575 5W40 MOBIL DELVAC ESP 25 K&N FF#2 6267
07/20/19 17036 5W40 MOBIL DELVAC ESP 5 K&N FF#3 4461
10/12/19 22185 5W40 MOBIL DELVAC ESP 2 K&N FF#3 5149
12/15/19 26822 5W40 SHELL ROTELLA T6 2 K&N FF$4 4637
Intervals seem a little short to me, but it does depend on how it is being used.  Heat cycles, power levels, rpm, temperatures, etc.
(which is the whole point of having an OLM, instead of relying on just odometer or hour meter readings.)
OLM does not sample the oil -- it monitors how it is used, and assumes that the oil in use is the spec/viscosity recommended in the manual.
4 hours ago, Gray said:
7500 miles is manufacture recommended
Actually, the dmax supplement maintenance section says to Check the oil level and OLM reading at 7500 miles...
Required Services Every 12 000 km/7,500 mi
. Check engine oil level and oil life percentage.
If needed, change engine oil and filter, and reset oil life system.
Edited by redwngr
