bshort Posted December 22, 2019 Share Posted December 22, 2019 25 minutes ago, TXGREEK said: Common sense isn’t yours either, I added additional factors as well. I’m no grease monkey, unless I’m changing my own oil, then things get messy but fun. Sent from Above A lift is an quantifiable additional factor? Time to change your screen name to TXTOOL. Quote Link to comment Share on other sites More sharing options...
bshort Posted December 22, 2019 Share Posted December 22, 2019 2 hours ago, LRod said: I think you have to consider his other facts as well. It's not just a new diameter. These LT tires weigh a heck of a lot more (mine are 64 lbs. a piece vs. thirty something pounds stock). Plus the aerodynamic changes from the increased height of the lift, plus the weight of the lift + components + new tread pattern and shape etc... Lots of factors at play besides the simple math that you are talking about. Sent from my Pixel 3a using Tapatalk That's not what TXTOOL said, he said "Btw folks, modified and or lifted trucks require much more engine oil protection as the engine works harder with bigger tires and taller trucks so not only has GM said OCI’s are to be made sooner (5K miles) in stock trucks but it’s more extreme wear on our engines too. Just food for thought!" It's all a load of crap and just regurgitated garbage from the fool. Quote Link to comment Share on other sites More sharing options...
TXGREEK Posted December 22, 2019 Share Posted December 22, 2019 That's not what TXTOOL said, he said "Btw folks, modified and or lifted trucks require much more engine oil protection as the engine works harder with bigger tires and taller trucks so not only has GM said OCI’s are to be made sooner (5K miles) in stock trucks but it’s more extreme wear on our engines too. Just food for thought!" It's all a load of crap and just regurgitated garbage from the fool. Wow! And your opinion is well documented. Let me start off by informing you that since you’ve joined this forum you’ve done nothing but criticize others for not agreeing with your thoughts. I was going to refrain from responding to your comment but after getting off the phone with the GM of a major off road truck/Jeep company, he said you sir are an idiot! Ok, we’re all entitled to our own opinion but you’ve made zero contribution to this thread other than criticize and now name calling. Hmmmm, you remind me of someone that was kicked off sometime back and being the time you joined, it all makes sense. But in all honesty, why don’t you inform us all what exactly is your contribution to this thread, other than attacking members with lots of experience?? Sent from Above 1 Quote Link to comment Share on other sites More sharing options...
bshort Posted December 22, 2019 Share Posted December 22, 2019 13 minutes ago, TXGREEK said: Wow! And your opinion is well documented. Let me start off by informing you that since you’ve joined this forum you’ve done nothing but criticize others for not agreeing with your thoughts. I was going to refrain from responding to your comment but after getting off the phone with the GM of a major off road truck/Jeep company, he said you sir are an idiot! Ok, we’re all entitled to our own opinion but you’ve made zero contribution to this thread other than criticize and now name calling. Hmmmm, you remind me of someone that was kicked off sometime back and being the time you joined, it all makes sense. But in all honesty, why don’t you inform us all what exactly is your contribution to this thread, other than attacking members with lots of experience?? Sent from Above Sure you did. It's ok for you to admit that you are incorrect and just embellishing to try and rationalize your use of Amsoil. Quote Link to comment Share on other sites More sharing options...
KARNUT Posted December 22, 2019 Share Posted December 22, 2019 Sure you did. It's ok for you to admit that you are incorrect and just embellishing to try and rationalize your use of Amsoil. Amsoil is good oil that’s been documented. Lifted trucks or modified trucks do create more work from the engine again documented. He’s even listed other oils that are good oils as had others. You made points about your options. So what’s the beef. Now the name calling. You have words, he’s provided pictures of his mods and work being done. Also articles, research and breakdown of oil analysis. You just name calling and opinion. You need to do better.Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
TXGREEK Posted December 22, 2019 Share Posted December 22, 2019 Sure you did. It's ok for you to admit that you are incorrect and just embellishing to try and rationalize your use of Amsoil. I’m never incorrect, as I’ve already said. re-gearing doesn’t fully take the stress off the engine on a lifted truck, I’ll leave it at that. Sent from Above Quote Link to comment Share on other sites More sharing options...
Jglew82 Posted December 22, 2019 Share Posted December 22, 2019 Just check the site, there are hundreds of pages of this subject, most times ending with fights between members (gets pretty funny along the way). And another self fulfilling prophecy comes full circle [emoji23][emoji23][emoji23] Quote Link to comment Share on other sites More sharing options...
SquireSCA Posted December 22, 2019 Share Posted December 22, 2019 16 minutes ago, TXGREEK said: This has got to be the same JackOff that uses that low cost Rotella. Starts with a J, added a new user names. Lmao! Sent from Above I use Shell Rotella T6 5W-40 in my street and track bikes over the years... as do many racers that I know. Never even a hiccup, smooth shifting, holds up well to extreme temps and motors spinning anywhere from 10k-16k RPM... It meets all the requirements in the manuals for Aprilia, Ducati and Triumph... Quote Link to comment Share on other sites More sharing options...
TXGREEK Posted December 22, 2019 Share Posted December 22, 2019 I use Shell Rotella T6 5W-40 in my street and track bikes over the years... as do many racers that I know. Never even a hiccup, smooth shifting, holds up well to extreme temps and motors spinning anywhere from 10k-16k RPM... It meets all the requirements in the manuals for Aprilia, Ducati and Triumph... Sent from Above Quote Link to comment Share on other sites More sharing options...
TXGREEK Posted December 22, 2019 Share Posted December 22, 2019 I use Shell Rotella T6 5W-40 in my street and track bikes over the years... as do many racers that I know. Never even a hiccup, smooth shifting, holds up well to extreme temps and motors spinning anywhere from 10k-16k RPM... It meets all the requirements in the manuals for Aprilia, Ducati and Triumph... Never said it was bad, just low cost. I used T6 in my diesels tooSent from Above Quote Link to comment Share on other sites More sharing options...
SquireSCA Posted December 22, 2019 Share Posted December 22, 2019 I specifically said the T6, which is the full synthetic. Quote Link to comment Share on other sites More sharing options...
TXGREEK Posted December 22, 2019 Share Posted December 22, 2019 I specifically said the T6, which is the full synthetic.It’s actually really good oil, believe it’s one of the best for diesels Sent from Above Quote Link to comment Share on other sites More sharing options...
bshort Posted December 22, 2019 Share Posted December 22, 2019 2 minutes ago, TXGREEK said: Never said it was bad, just low cost. I used T6 in my diesels too Sent from Above What does the 1 minute ago, TXGREEK said: It’s actually really good oil, believe it’s one of the best for diesels Sent from Above Has to be a far superior Amsoil product because it is priced higher. Hahah. You're all over the map. Quote Link to comment Share on other sites More sharing options...
TXGREEK Posted December 22, 2019 Share Posted December 22, 2019 Has to be a far superior Amsoil product because it is priced higher. Hahah. You're all over the map. The Rotella T6 is great for diesels, the Rotella for gasoline is notSent from Above Quote Link to comment Share on other sites More sharing options...
bshort Posted December 22, 2019 Share Posted December 22, 2019 1 minute ago, TXGREEK said: The Rotella T6 is great for diesels, the Rotella for gasoline is not Sent from Above T6 has also has great results in gas vehicles. Turbo Subaru's are one example. Quote Link to comment Share on other sites More sharing options...
