Push button start Starter cranks endlessly no crank
  • 4 weeks later...
On 12/11/2019 at 4:18 PM, 19RSTZ71 said:
Towed to dealer says it started. 2019 Silverado RST Crew 5.3 left me stranded at zero degrees.  I pressed the start button and the starter cranked at high rpm without the bendix engaging to crank the engine.  I had to press the button to stop it from spinning.  Tried several times still only starter spinning.  Roadside tow last night to dealer.  Dealer said started fine had a few codes ie fuel pump etc.  said come and get it NPF.  Now that is disappointing from a reliability trustworthy stand point.   Curious if anyone has heard of this symptom.  3024 miles on vehicle.
  • 2 years later...
Having same issue 2019 Silverado high country 6.2 at first it will do it intermittently after the 2nd try it will turn on. Now I have to wait 10 min and it will start like nothings wrong with it. You can hear the starter spinning but it’s not engaging. And sometimes I hear the teeth grinding as if it semi engages only. New starter and still same issue
