calgator73 Posted September 4, 2020 Share Posted September 4, 2020 3 hours ago, TheElementalCashew said: This is the only one I have a the moment. Notice the hourglass in the top left, and the missing parking lines. 360 view is the most messed up, as you can see by the yellow parking lines. Thanks...I'm going to do some research and see if Whites or another company like that can flash a BCM/infotainment with the correct software. Quote Link to comment Share on other sites More sharing options...
TheElementalCashew Posted September 4, 2020 Share Posted September 4, 2020 Thanks...I'm going to do some research and see if Whites or another company like that can flash a BCM/infotainment with the correct software.I already asked them, they said they would look into it, but haven’t had much actual engagement from them. Quote Link to comment Share on other sites More sharing options...
pewterliftedz Posted September 4, 2020 Share Posted September 4, 2020 4 hours ago, calgator73 said: Thank you! Window switch too right for the power extend feature? Only fully loaded HD mirrors have power extend and puddle lamps. None of the tow mirrors for the 1500 have those options. Quote Link to comment Share on other sites More sharing options...
pewterliftedz Posted September 4, 2020 Share Posted September 4, 2020 (edited) 9 minutes ago, TheElementalCashew said: I already asked them, they said they would look into it, but haven’t had much actual engagement from them. If I had to guess, I bet it's the camera module behind the rear seat that needs to have a different software installed to process the different data. There is a guy that put 360 cameras onto his RST, I bet he could help. Edited September 4, 2020 by pewterliftedz Quote Link to comment Share on other sites More sharing options...
pewterliftedz Posted September 18, 2020 Share Posted September 18, 2020 On 9/1/2020 at 7:16 PM, chris84 said: I'm planning to swap mine this weekend to the tow mirrors & harnesses . Hey man did you ever get your mirrors and harness swapped? My door harness’ should be here Saturday from GMpartdirect Quote Link to comment Share on other sites More sharing options...
chris84 Posted September 18, 2020 Share Posted September 18, 2020 Yes, didn't have time to post before heading out west after I got them on. As expected the mirrors adjust, fold, heat all work. For the lights - the orange marker lights & blinkers work, forward facing task lights work, the rear facing task lights do not work - I haven't had time to read what which button should turn them on though. Cameras are skewed as others have reported. I don't know if it was doing this with the regular mirrors or not, but the passenger blind spot indicator often does not illuminate when passing semi's, seems to work on cars & pickups though. It did seem to work if I slowly passed a semi. When you install the harness make sure you get the wiring around/behind the window track at the back (near the handle) of the door. Quote Link to comment Share on other sites More sharing options...
pewterliftedz Posted September 18, 2020 Share Posted September 18, 2020 (edited) 7 hours ago, chris84 said: Yes, didn't have time to post before heading out west after I got them on. As expected the mirrors adjust, fold, heat all work. For the lights - the orange marker lights & blinkers work, forward facing task lights work, the rear facing task lights do not work - I haven't had time to read what which button should turn them on though. Cameras are skewed as others have reported. I don't know if it was doing this with the regular mirrors or not, but the passenger blind spot indicator often does not illuminate when passing semi's, seems to work on cars & pickups though. It did seem to work if I slowly passed a semi. When you install the harness make sure you get the wiring around/behind the window track at the back (near the handle) of the door. Cool thanks, the button for the rear facing lights is the cargo lamp that turns on the bed lights. Edited September 18, 2020 by pewterliftedz Quote Link to comment Share on other sites More sharing options...
chris84 Posted September 18, 2020 Share Posted September 18, 2020 1 hour ago, pewterliftedz said: Cool thanks, the button for the rear facing lights is the cargo lamp that turns on the bed lights. That's what I thought but was not positive. Quote Link to comment Share on other sites More sharing options...
chris84 Posted September 29, 2020 Share Posted September 29, 2020 On 9/18/2020 at 9:17 AM, pewterliftedz said: Hey man did you ever get your mirrors and harness swapped? My door harness’ should be here Saturday from GMpartdirect Did you swap your harnesses? Quote Link to comment Share on other sites More sharing options...
C5 Pete Posted September 30, 2020 Share Posted September 30, 2020 Cool thread. I'm new to the forum. I recently totaled my 2012 Avalanche and picked up a 2020 GMC Sierra SLT with the max towing package. Like others in this thread, I need/want better mirrors for towing a 28' enclosed trailer. A lot of the replies here refer to the Chevy trucks, I'd like to presume it would be all the same for GMC. but... I have the convenience package with power folding, adjustable, heated, mirrors. I'd like to retain that stuff, but get the tow mirrors like in this thread. Any insight would be helpful. Thanks Pete Quote Link to comment Share on other sites More sharing options...
C5 Pete Posted September 30, 2020 Share Posted September 30, 2020 These mirrors? I have lane alert, so these won’t work? Or they’ll work fine, but I’ll no longer have lane alert? Quote Link to comment Share on other sites More sharing options...
pewterliftedz Posted September 30, 2020 Share Posted September 30, 2020 On 9/28/2020 at 8:55 PM, chris84 said: Did you swap your harnesses? Not yet, I'll get to it one of these days haha. Quote Link to comment Share on other sites More sharing options...
pewterliftedz Posted September 30, 2020 Share Posted September 30, 2020 (edited) 7 hours ago, C5 Pete said: These mirrors? I have lane alert, so these won’t work? Or they’ll work fine, but I’ll no longer have lane alert? You'll lose blind spot, puddle lamps, task lamps, and power folding with those mirrors. You'll have to do what I did and buy the fully loaded tow mirrors that have cameras. They cost about $1200 per side at the dealer, online about $850 plus shipping, or find them on ebay like I did for $200-$500 per side. Edited September 30, 2020 by pewterliftedz Quote Link to comment Share on other sites More sharing options...
C5 Pete Posted September 30, 2020 Share Posted September 30, 2020 8 minutes ago, pewterliftedz said: You'll lose blind spot, puddle lamps, task lamps, and power folding with those mirrors. You'll have to do what I did and buy the fully loaded tow mirrors that have cameras. They cost about $1200 per side at the dealer, online about $850 plus shipping, or find them on ebay like I did for $200-$500 per side. Thanks for the quick reply. What features will I retain if I go with the fully loaded mirrors like you did? Quote Link to comment Share on other sites More sharing options...
pewterliftedz Posted September 30, 2020 Share Posted September 30, 2020 (edited) 5 minutes ago, C5 Pete said: Thanks for the quick reply. What features will I retain if I go with the fully loaded mirrors like you did? Everything still works, I haven't lost any original features. Edited September 30, 2020 by pewterliftedz Quote Link to comment Share on other sites More sharing options...
