- 0
2018 Canyon Check Engine Light and Service Stabilitrak
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 2 Members, 0 Anonymous, 1,070 Guests (See full list)
Question
cjerm22
I bought a brand new 2018 Canyon this past April. At 7,200 miles on a cold weather start (The first cold day of the year) the service stabilitrak light, traction control light and check engine light came on (flashing). Engine was sputtering at idle. Put the truck in drive and drove a couple of feet and the engine light turned off. Shut the truck down and started it back up and everything was fine; all lights off.
I took it to the dealer and they got a P0300 random misfire code and after some diagnosis determined it could be caused by a faulty fuel injector which was replaced and all was well for 3 weeks/700 miles until last night the same issue occurred (All three lights) on a cold weather start after it had been sitting for 24hr. This time the sputtering was worse and the headlights were flickering. Drove it a couple of feet and the sputtering stopped. Shut the truck off, started it again and the service stabilitrak and traction control lights went off, however, this time the check engine light stayed on. Called OnStar on the way home and they scanned the code which resulted in a P0300 code again. The truck seems to be running fine since, but the light is still on. I should also note that while the truck is running, if I open the door and the dome lights come on they have a very slight flicker. If the engine is off and dome lights are on there is no noticeable flicker.
Had anybody else had a similar issue? Went to the dealer and they can’t get the truck in until Friday.
3 answers to this question
