Filter Intervals
Coming up on 40k miles and a couple of questions related to filter intervals on my 2016 LML.
I bought my truck from a dealer that does lifetime oil and filter changes with a dedicated diesel mechanic so oil/filter is every 5k.  Usually ends up around 35% on the gauge.
For the fuel filter, I planned to follow the gauge but found some conflicting information.  I went ahead and did the fuel filter at 30k because honestly, I cant figure out what you are supposed to do.  the manual states 22,500 miles or two years but at 30k miles and almost 3 years the gauge was at over 50%.
For the transmission, I haven't changed the spin on yet.  Manual seems to refer to 45k for spin on and then a full service at 90k.  I'm not towing a lot and my transmission temps are under 100 degrees most of the time.  Does that seem right?
I was going to do transfer case/diffs at 50k (understood those aren't filters :))
Fuel filter should be changed the earliest of:
22,500 miles (36,000km)
2 years
0% on DIC
If you drive a lot it's likely to be miles.
If you drive a little it's likely to be time.
If you get some dirty fuel it's likely to be %.
If you prefer to use the 'severe service' schedule the first trans fluid and external filter change is at 45,000 miles, then 90k intervals.
    247.7k
    2.6m
    Semyon Glinkin
    Semyon Glinkin
  • Who's Online   4 Members, 0 Anonymous, 381 Guests (See full list)
