How has Voyager 1 and 2 not melted?
SnakeEyeSS
If anyone has been following the recent space news Voyager 2 is passing the heliosphere and is confirming what Voyager 1 saw, that's it's around 90,000°F degrees outside our solar system. In fact, the lowest temps they found are higher than what the biggest minds in science thought was probable.
Besides another great reminder that the usually smug(you know, the ones that used to say there probably wasn't any other Earth like planets in the Galaxy) theorectical scientists are nearly always wrong about what is outside our planets and how the universe works:
HOW DID THE THINGS NOT MELT!
I have read three articles about it and they says the probes are swimming along nicely. Considering we can't make a metal that can survive those temps now, and especially since the Voyagers were built in the 70's......HOW?
I haven't seen anything that suggests it's got some kind of IR type thermometer and it has luckily avoided the pockets of the plasma, which is the only thing I can think of.
Edited by SnakeEyeSS
Is the sensor reporting correct thermal data, or is age/range affecting the data?
I've had thermocouple wire at work develop a short and report +/- 645C in a 25C room.
Also, to experience that level of heat, something has to be generating it. If they aren't near the sun or a star like it, where is the heat coming from?
Sent from my SM-J810F using Tapatalk
T ithey are saying it's pockets of interstellar plasma that our sun's solar winds keep out. Think of how the Earth's magnetic fields blocks us from flares, this is about the heliosphere, basically the sun's field that blocks the bad stuff like radiation from outside the solar system.
You you leave the Earth's atmosphere it's very cold, when you leave the sun's protection it seems to get crazy hot.
I'm with you, I'm more inclined to believe that there is something affecting the temperature "sensors" in the same way that makes it think it's crazy hot, because I don't see how we could have built anything that could withstand those temperatures. I mean, didn't they have to build those things in suits to avoid any contamination, not like they could just spray some Lysol on it before launch and call it good.
And that's seems like a HUGE factor all these articles are just ignoring or not thinking of asking about.
Maybe tomorrow we will get an actual picture of the earths core taken by a old cellphone camera, and no one asking "how did we get this picture".
I won't link to a specific article, there are multiple with varying amount of info if you are interested, just search for Voyager 2 .
From this site: https://www.nationalgeographic.com/science/2019/11/interstellar-space-weirder-than-expected-nasa-voyager-2-reveals/
"And on the other side of the boundary, the interstellar medium is at least 54,000 degrees Fahrenheit, which is hotter than expected. However, this plasma is so thin and diffuse, the average temperature around the Voyager probes remains extremely cold."
An analogy would be sand on a hot sunny day.  You can step on the beach, and burn the heck out of the bottom of your feet, but if you took just a single grain of sand, same temp and it was dropped on your arm, you likely wouldn't even notice it, or get burned by it.
It sounds like there are some very hot particles floating around in space, but given that space is predominately a vacuum, there isn't enough of those particles around the spacecraft to significantly damage it.
Yeah, so how did they get that temperature then? I figure some sort of spectrography instrument which is how the measure it now, but did we have one that could fit on it in the 70s? I honestly don't know.
But, to that Nat Geo article, that is Voyager 2, but Voyager 1 WAS hit by plasma.
https://www.space.com/amp/22797-voyager-1-interstellar-space-nasa-proof.html
This is as annoying as the Orion program NASA video that leaked that said they are testing  if astronauts can survive the Van Allen belt. Uh, hello, the Apollo guys made it through twice each time. (Well, most of them).
The only way around the below is that the "jolt" was from a shockwave type of reaction, but I'm giving them credit that wasn't stated.
Quote
But in April 2013 scientists remembered that Voyager I had experienced bursts of radio waves in 1983 to 1984 and in 1992 to 1993 when interstellar plasma was bombarded with a huge blast of solar material. They expected to find similar oscillations once Voyager was jolted by interstellar plasma.
On April 9, they noticed those oscillations, which likely occurred a year before due to a solar storm around St. Patrick's Day.
I think you just answered your own questions. Watch Capricorn One if you haven't seen it.
