Grumpy Bear Posted November 19, 2019 Share Posted November 19, 2019 https://www.consumerwatchdog.org/resources/DPReportHotFuelUSAJune07.pdf At retail, oil companies buy at one temperature and sell to consumers at another. However, retail sales are not temperature-adjusted. Though technology exists and has been accepted for near universal use in Canada, no U.S. retailer of gasoline compensates for temperature when selling to consumers. As a result, when temperatures of gasoline rise above the 60 degree standard, as is the case in the U.S. during the summer, the amount of gasoline by weight decreases in a gallon, and the effective price per gallon increases. For instance, let’s say that Consumer C pumps 20 gallons at Retailer D’s gas station, and assume that the actual temperature of the gasoline is 90 degrees Fahrenheit, and the consumer is paying $3.50 per gallon. Due to the thermal expansion of gasoline, the retailer only had to deliver 19.59 temperature adjusted gallons to make 20 gallons at 90 degrees. The consumer, therefore, paid the retailer a premium on top of his costs for the gasoline and station operation, profit and excise taxes of $1.44. Stated another way, the consumer effectively paid about $3.57 per gallon, not the advertised $3.50. [end quote] Researching the thermal expansion of gasoline to make sense of my twice a year adjustment to my fuel meter for the Scan Gauge II and I ran across this link above. Using Peppers life time average 27.5 mpg we cover 538.7 miles on 19.59 gallons. 20 gallons then shows 26.9 mpg or 2.1%. Each 30 degrees either side of 60F is then a 2% shift. 10% total from 35 F below to 115 F. BTU content winter to summer only moves 1.5% so winter gas isn't the issue. Just say' n. Quote Link to comment Share on other sites More sharing options...
tbarn Posted November 20, 2019 Share Posted November 20, 2019 Where is one to pump gas at 90 degrees out of the ground? Quote Link to comment Share on other sites More sharing options...
Colossus Posted November 20, 2019 Share Posted November 20, 2019 Arizona? Quote Link to comment Share on other sites More sharing options...
riverbanks Posted November 20, 2019 Share Posted November 20, 2019 In n.y., bureau of weights and measures is constantly checking with a container,can't get away with nothing around here Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted November 20, 2019 Author Share Posted November 20, 2019 1 hour ago, riverbanks said: In n.y., bureau of weights and measures is constantly checking with a container,can't get away with nothing around here Every state does. DOT. Delivery is by volume but BTU content is by weight. Pumps sell by volume. When that volume has less weight it has less BTU's and the means you burn more volume. If you looked at the link you might have noticed this: STAFF REPORT of the Domestic Policy Subcommittee Majority staff Oversight and Government Reform Committee House of Representatives Dennis J. Kucinich, Chairman Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted November 20, 2019 Author Share Posted November 20, 2019 2 hours ago, Colossus said: Arizona? Well according to the report the gas volume tested is normalized to 60 F and as the report is about hot weather effects on the consumer, yes...Arizona would be getting the bad end of the stick. Look, guys, this is just information I ran across that I though you might be interested in. I investigated it for personal reasons. Quote Link to comment Share on other sites More sharing options...
JimCost2014 Posted November 20, 2019 Share Posted November 20, 2019 3 hours ago, tbarn said: Where is one to pump gas at 90 degrees out of the ground? How far are you from Hell, Michigan? Quote Link to comment Share on other sites More sharing options...
