Block Heater Cord Temp. Sensor
I found an M8 regular nut dropped into the hole that the little thermostat came out of & makes the connection nicely, just pushed the black plastic cap back on & taped it back in place.
Sent from my SM-A705W using Tapatalk
  • 1 month later...
On 11/18/2019 at 10:25 AM, Salsa De Piña said:
I just recently picked up a new '19 Legacy, and was checking out the block heater cord as it's that time of year.  It appears to have a normal plug, without the temperature sensor.  Has GM gone away from these, or is the temperature sensor somewhere else?  The manual says the thermostat may exist in the plug end, but I figure that's because the Duramax probably doesn't have one.
Where did you find the cord. I have the '19 legacy and I can't seem to find the cord
