  • Sign Up
2016 Silverado 1500 battery/Cruise Control / Electrical Issues
Recently had battery drain drastically on my 2016 1500. Does not want to charge on the battery charger.  I can get it to start and, when running, the cruise control doesn't work and the USB ports on the center console don't seem to work; however, the USP port inside the storage area of the console does work.
Only thing I had done differently lately is involves messing around with the cruise control, based on reading something in the manual  that said that if I held down the cruise control "set" button while in park with the e brake on it would idle at a set RPM.  That never happened, but there may be some consistency between doing that and the problems I am having.
Any thoughts?
Reply to this topic...
