- 0
Antilock Brake System Automated Bleed (OBDII scan tool)
Similar Content
- 2 replies
- 3,087 views
- 7 replies
- 6,540 views
- 5 replies
- 10,257 views
- 5 answers
- 14,966 views
- 0 replies
- 998 views
Recently Browsing 0 members
247.6k
Total Topics2.6m
Who's Online 19 Members, 0 Anonymous, 2,156 Guests (See full list)
Question
dye
I just did the brake pipe kit install on my '01 K2500 Suburban. I have a friend with a Bosch scan tool that is able to command the ABS unit to run its self-bleed routine.
What I am missing is the "how to" properly do this procedure.
I have access to the Chilton's for my year Suburban, and it has a "Antilock Brake System Automated Bleed" section. It starts out with a full normal bleed, followed by
Step 10: Press the brake pedal firmly and run the Automated Bleed Procedure. Release the brake pedal between each test.
Sadly, no mention is made of the actual mechanics of the "Automated Bleed Procedure".
Could someone cue me in? How many test sequences need to be performed. Truck running, or not running? I assume the procedure lets air in the ABS block to get pushed out towards the calipers. Do you need to crack a bleeder on each of the three circuits (rear, RF, LF) to make room so the air has someplace to go?
I did search the forums, with no success. Thanks in Advance!
4 answers to this question
