Leveling kits? If so, let's see them.
 My truck was only 1 and 1/4” higher in the rear than the front, stock. I kept mine pretty simple, I dialed in an inch on the front. That took out most of the rake. But didn’t put it dead level.
I like my tread blocks flush with the fender and not sticking beyond. I went with a 20x9 +12 wheel and a 295/65/20 tire. That tire measures 35.3” tall. Which puts it right in between a 35 and 37. Tires labeled 35, typically measure in mid 34” range and tires labeled 37 typically measure in mid 36” range.
I have zero rub. Off road at full lock, I would expect some fender liner rub. But have not encountered it yet.
  • Like 6
Nice looking truck, what wheels do you have?
1 minute ago, EIKON said:
Thank you. The wheels are some inexpensive wheels from Vision. Vision Turbine
Would you be able to post some more pictures as I would like to see how far they stick out from the fender well?
These are 20x9 +12. I had tried to stay with a 20x9 +18. I just had a hard time finding a wheel that fit my tastes. I wasn’t looking for a black or a chrome wheel. So the choices start getting limited.
Change your taste, you’ll have more options ;) jk! Yeah outside of black or chrome the options are much more limited!
On 12/31/2019 at 11:49 AM, Big Skin said:
Update: Monday I will be getting my chrome Fuel Contra 22x10 on Nitto Trail Grapplers 35x12.50x22. I wanted to keep the ride quality so I was going to get a leveling kit with the arms and shocks but surprise they don't make a kit like that for a Denali with Magneride yet. Arg I guess I will be adding the arms and other components as they are released but for now I guess my ride will suffer a little. I will post pics as soon as I get it done.
Well it appears I have been lied to because after more research it appears that my Denali does not have Magneride.
According to a press release GM replaced Magneride with active damper shocks. Although a post from MTU Alum on Dec 31 2019 stated that "none of the HD trucks have active dampers" but even my build sheet does not say Magneride it only says Rancho Shocks as it has the Z71 package. The press release speaks about the 2019 I assume it's the same for 2020
2019 Sierra Denali: Adaptive Ride Control Replaces MagneRide
When it launches later this year, the 2019 Sierra Denali will feature a new suspension control technology called Adaptive Ride Control (ARC).
GMC tells us that ARC delivers “premium driving refinement with exceptional responsiveness”, with “a high level of primary vehicle motion control, but with better ride isolation”. The system consists of three components:
  1. Active dampers that are individually controlled every two milliseconds in a continuous range between the softest and firmest damping
  2. Relative wheel-to-body position sensors at each wheel
  3. A dedicated control unit with integrated sensors that detect heave, pitch and body roll motion
Damping is adjusted at each individual wheel when the Sierra is cornering, braking and accelerating, and damping rates will change when Sport mode is selected by the driver, or automatically when the system detects heavy trailers or large payloads.
Not Magnetic Ride Control
Don’t let the name fool you: Adaptive Ride Control (GM RPO code Z45) is not just another name for GM’s incredible Magnetic Ride Control, since ARC does not use magnetic dampers/magneto-rheological fluid. Instead, it uses different (and perhaps less sophisticated) active dampers.
Think of Adaptive Ride Control as Magnetic Ride Control “light”. Another way to look at it is that of a version of Continuous Damping Control, which is available on GM cars like the Buick Regal and LaCrosse and crossovers like the Buick Enclave, Cadillac XT4 and XT5, as well as the GMC Acadia, but adapted for the requirements of a pickup truck.
Just did this....
3+1 kit
20X9 0 offset wheels
35X12.50X20 Ridge Grapplers
I get a slight rub when backing up with steering turned. It rubs the liner material inside the wheel well, but I think it can be easily fixed as the liner has some play and I should be able to somehow move it away a couple of inches.....I just need to investigate more to see how I would fasten it to keep it back to where the tire clears.
  • Like 5
20 minutes ago, Muleytime said:
Just did this....
3+1 kit
Looks awesome!  Is that the Rough Country?
On 12/23/2019 at 10:19 PM, arnoldsabino said:
My AT 4 also done at Dennis Dillon dealership in idaho, where I took delivery of my at4 dec 16... 2.5" +1" level kit with fox shocks, 35x12.5 R20 BFG TKO2 tires... the first pic shows the difference between the rest on the Lotd75df0778239fa50709132a0432c86ba.jpg99c46173f8ee15555abfe8e61d679e90.jpg5fd8f76eda618ac7c6e86f9969cd6f5f.jpg19248dbfb6c2bf0b20548e35b54f9ad3.jpge746e8b2582c58b91377d6cfbf8bb956.jpga7d3f8302fa58d56d5c4ed3ae8755bed.jpg3c717e52e2707e5592a8b9fa37f92205.jpg
Sent from my SM-N976V using Tapatalk
No offense taken. Just seeing this picture the at4 looks taller than denali at the lot and wanted to confirm. But now re reading the post the level was already don’t so yes, it is taller in the pic
Edited by Kfroese
6 hours ago, BB&Chiveon said:
no offense- but for the 100th time .  on the 2500HD - there is no difference in heights on at4 vs denali - ONLY 1500's
So you're telling me there's a chance!
haha sorry, had to ? Yeah it's surprising how much confusion that topic has caused with the 1500's being the only one with the added AT4 height.
On 1/30/2020 at 11:26 PM, Muleytime said:
Just did this....
3+1 kit
Dont leave us hanging brother,  RC 3 + 1?
