Anyone get the 9L7 Upfitter AUX switches
On 4/28/2020 at 9:50 PM, PaulpHebert said:
Yes, but just the studs.  Does anyone know where I can get them?
Sorry for I’ve not been able to come up with the individual component part numbers contained within this kit. Anyone in here at a dealership that can look up the individual components that comprise the kit.
Why don't they ever put a description of these?  I think if this contains the studs for the power distribution unit, I may just purchase the whole thing.  At $38, it's not that bad.
On 4/9/2020 at 7:56 AM, Zelas said:
Do it ! Its a fun project to do. I put mine to good use.
Will it be possible to provide complete list of materials and/or a "KIT" part number associated with all parts found?
Thanks,
Regards.
Any pictures?
Thanks,
Regards.
Any pictures?
lots of pictures & complete part lists in this thread!  Just have to go back a few pages!
Want to add up fitter switches but hesitant to order parts because of this message comes up from gmupfitter.com anyone have any insight or knowledge of this thanks in advance
On 3/22/2020 at 9:09 PM, William Sherman said:
That is the 5 switch module. The outputs from the relays associated with switches 1-4 are left blunt cut in the harness. The output from the relay associated with switch 5 is within the vehicle plug and does provide power to the roof beacon circuit(located behind the CHMSL). But that could also be modified by removing the relay output from the vehicle plug.
I just installed this stuff this week. The battery cable was still on back order so I constructed my own.
Would you share the details of the battery cable? Piece of wire & some crimp on ends? If I can save $40 I have no problem making one.
I guess two things:
1. I'm also probably going to wait until this message goes away...
2. which of these four kits (that show up now on GM Parts Direct) do I need?  I've got a Custom trim, no push start bolster.  Can't really tell what is different between these four:
84756681
84756682
84756684
84756685
7 minutes ago, ROOK Lucky 13 said:
I guess two things:
84756681
84756682
84756684
84756685
that same message popped up when i ordered my parts & i installed them no problem, everything works perfect, so i wouldn't be too worried about it.
there's also really good parts diagrams on gmpartsdirect.  this is how i found the part numbers for what i ordered, maybe its what your are looking at too?
Here are the 4 options for the knee bolster.  Its basically with or without push button start, black or grey (atmosphere) interior.  hope this helps.  Your dealer can verify for you.
Is anyone having an issue purchasing kit 84699070?  I am being told it is not available.  I have everything but this kit for the install.
has anyone found a way to hook the factory cable to the battery without this kit?
After months of waiting for the kit, I fabricated my own cable to the battery.
I cut off the OEM battery cable connector plug on the harness connected to the fuse/relay module. Utilized a length of 8awg cable, wire loom, crimp connectors, 30amp fuse at the battery, and zip ties. Utilized the OEM pass through at the firewall.
Two months later, still works flawlessly. It’s just a power cable, the only thing fancy are the OEM exclusive connector plugs. Use an alternative 8awg connector or a butt splice connector.
Edited by William Sherman
Figuring out how to get the dash apart without breaking something or leaving a mark to install the bolster was the hardest thing about this install.
Now who’s figured out how to easily remove the third brake light to gain access to the interior of the spoiler?
You need more than the bolster and switch, you also need the switch harness. Check prior posts in this thread for that part number.
