Another wheel/tire question for 3 inch lift
Hey All,
Just ordered some Icon coilovers for my 2019 Sierra that have adjustable height of 1.5-3.5" of height. I also have a 2 inch rear lift block in my garage.
Now the next thing I need to do is decide on my wheels and tires deciding between a 20 inch wheel or 18 inch wheel because I sometimes really like the look of the smaller wheel with more tire. Looking at minimum of 34" of height ideally..
I really dont want to rub or do major trimming but I also dont want something that'd look to small for a lift that'd go up to 3.5 inches. I like the look of the wider stance and not the tiny pizza cutter tires. Just trying to find that sweet spot. Looking for any suggestions/help please.
Been looking around and seeing 295/70/18 that on some tire sites say its a 34.4" height but its a 11.5" width? But some say 11" so not sure about that route but any info with pictures would be very helpful
Edited by jordanl010
  • 4 weeks later...
I'm looking at doing the same with mine. Just got a pair of CST coilovers I'm having installed. Everything I'm hearing is anything larger then 33" x 11.5" will require some trimming on Sierra 1500.
8 hours ago, Vardo79 said:
I have the CST setup and I run a 34.8” tire on 18’s. Fits perfect.
Now that is a great looking truck! Couple of questions..
1. What height are you running the coilovers at?
2. How's the ride? and did you run into any issues.
3. Any side pics? :)
I was told right at 3.5”. On a soft setting I top out sometimes. I went with 5 clicks and it eliminated it but ride is much stiffer. Also once I installed air bags in the rear, my ride height is 1” off. Rear higher than front. I have the 6.2L engine so I’m thinking it’s a little heavier than The 5.3L and that’s why it’s different than what people are saying in the 5.3L setups. . CST is supposed to look at it soon to see if I can raise in the front  If not I’ll look into a 4” lift.
Edited by Vardo79
That looks incredible! THank you for all the info!
  • 1 year later...
